Editing .AVI files in Final Cut Pro 5
Jason Luna
on Dec 23, 2011 at 8:02:51 pm
I am trying to edit .AVI files in Final Cut Pro 5.
I have converted the files to .MOV files w/Quicktime.
I placed one of the .MOV files in FCP 5, and can view it fine in the Viewer.
But when I place it in the Sequence, it plays with a screen saying "UNRENDERED".
I can render the footage, I suppose, but based on past experience, that would make it harder to edit.
Thanks for any help I can get in regards of how to edit .AVI files.
Shane Ross
Re: Editing .AVI files in Final Cut Pro 5
on Dec 23, 2011 at 9:43:55 pm
Converted to what codec of .mov? There are dozens. FCP only works with editing codecs. Look in the Easy Setup list to see what your options are.
Shane
Little Frog Post
Steve Eisen
on Dec 23, 2011 at 9:44:55 pm
[Jason Luna] "I have converted the files to .MOV files w/Quicktime."
.mov is just an extension just like avi. You need to convert to a FCP friendly codec such as ProRes.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Shane Ross
on Dec 23, 2011 at 9:46:47 pm
FCP 5 doesn't do ProRes.
Shane
Little Frog Post
Andrew Rendell
on Dec 23, 2011 at 9:46:58 pm
You're doing the right thing to convert to Quicktime, but what codec are you using? It needs to be an editing one, then when you edit you should have the sequence setting on the same codec as the quicktimes to avoid having to render. IIRC, Apple Intermediate Codec (AIC) or DV would be suitable for FCP5.
