Never thought I'd be doing this again...It's nearly 2012
Ben Oliver
on Dec 22, 2011 at 3:54:45 pm
I need to capture VHS.
I have FCP7.
I have a DSR11 Deck
I have rca cables.
I have a firewire deck.
I can capture DVCAM tapes fine via firewire.
The outputs on the VCR are fine and work.
I can record the VHS to DVCAM fine.
My FCP Settings are set to non-controllable device and DV NTSC 48k
My scratch disc is a firewire 800 drive.
I cannot seem to get the video to passthrough. all the parts are working, but not the whole...
Thanks for your help!
Chris Babbitt
Re: Never thought I'd be doing this again...It's nearly 2012
on Dec 22, 2011 at 4:05:21 pm
Is the input on the deck set to"Line?"
Ben Oliver
on Dec 22, 2011 at 4:05:46 pm
Yes...I got it to work....with QUICKTIME 7......
-Ben
Dave LaRonde
on Dec 22, 2011 at 4:07:52 pm
Dub the VHS to DV. Capture the DV as normal.
And who knows? Some day someone may want to include old kinescope Honeymooners episodes in an edit.
Or a Bing Crosby Christmas special produced at Television City In Hollywood on quad machines.
History isn't going to go away.
Dave LaRonde
Sr. Promotion Producer
Ben Oliver
on Dec 22, 2011 at 4:10:52 pm
Theres just like, 400 tapes here, and that will basically double the time. I think I will just capture right into the machine and make dvds where appropriate!
But thanks for the advice!!!
-ben
Mark Suszko
on Dec 22, 2011 at 5:16:05 pm
With 400 tapes to capture, I think what I would do is buy a tunerless DVD recorder for less than a hundred bucks, dub the VHS over to DVD-R's, then use the DVD's as archive and edit source, converting them to work on my FCP-7 timeline with Squared-5's mpeg streamclip free utility, or use (shivers) FCP-X. The DVD's will import really fast, and you can be editing while the DVD recorder is capturing next door.
Ben Oliver
on Dec 22, 2011 at 9:57:17 pm
Thanks for the advice!
