strange colour lines on image in FCP
Marc Lucas
on Dec 21, 2011 at 11:33:44 pm
Had some large Jpeg files that I resized (sized down) in PS to a manageable size for use in FCP. I created both TGA's and PS files. Whilst resizes the file down further to anymore scale and motion in FCP I have noticed that on some 'edges' there is some colour lines along some of the objects i.e down the straight edge of a work surface etc. Its like a banding effect when the image moves. What causes this and can I stop it?
Shane Ross
Re: strange colour lines on image in FCP
on Dec 22, 2011 at 12:01:08 am
IN the sequence settings, set FIELD DOMINANCE to "None."
Also, FCP likes PNGs and TIFFs...not PSDs and not TGAs.
Shane
Little Frog Post
Marc Lucas
on Dec 22, 2011 at 12:03:44 am
Sequence is already at 'none' I always work in progressive 720p
I usually always work with TGA files and never had any issues before. Could it be the scaling of the images that cause this though?
Thanks for the reply
Shane Ross
on Dec 22, 2011 at 12:07:14 am
Scaled from what to what?
Shane
Little Frog Post
Marc Lucas
on Dec 22, 2011 at 12:13:30 am
900x600 to 450x300 approx
Shane Ross
on Dec 22, 2011 at 12:16:40 am
[Marc Lucas] "900x600 to 450x300 approx"
GAH! Don't do that! You are making the wicked small! 900x600 is fine. Perfect for SD sizes...and kinda small for HD projects. But 450x300 is pretty darn small. You are adding compression artifacts when you do this, and then blowing that up in FCP to fill the window...and so bringing them out more.
Shane
Little Frog Post
Marc Lucas
on Dec 22, 2011 at 12:19:24 am
Sorry didn't explain fully the image isn't actually full screen its one of three image boxes that occupy the screen with a small movement. It takes up possible a quarter of the viewer.
Shane Ross
on Dec 22, 2011 at 12:29:16 am
Well...it's pretty low resolution, that might be the reason.
Shane
Little Frog Post
Marc Lucas
on Dec 22, 2011 at 12:33:17 am
This is the process I took. The original image in PS was 5000x3999 I used the crop tool to crop three sections from the picture all of the pieces around 900x600 give or take. Those three images were saved as TGA & PSD (I'll look into using PNGs and TIFF in the future now, thanks!) and brought into FCP. they were then down scaled by 60-70% to fit into the viewer.
Marc Lucas
on Dec 22, 2011 at 12:07:52 am
Just tried with both a PNG & TIFF and got the same results. The problem happens when the image is scaled below 60% of the size it was saved in PS
Shane Ross
on Dec 22, 2011 at 12:13:16 am
Actual dimensions please. Like...from 6800x3400 to...3800x1700? or...?
Shane
Little Frog Post
Neil Ryan
on Dec 22, 2011 at 9:25:21 am
Doesn't sound like your problem, but others report similar issues on stills in FCP. But it goes away once rendered. I trust your talking about a rendered timeline?
Neil.
