Color Correction drops out part way through clips after export in FCP 6
Ben Knight
on Dec 21, 2011 at 3:37:55 am
Hi guys, got a strange thing happening...
Using Final Cut Pro 6.06 in snow leopard.
I have my sequence in ProRes (not HQ), which I converted from H264 from a Canon 5d MK II.
I've applied FCP Color Corrector to most of the clips / cuts.
When i export to quicktime movie (not qt conversion), using current settings, and I don't make self contained or recompress frames, the color correction sometimes is just not there for a few frames in certain random clips. There are no keyframes in the sequence that would make this occur. The color correction is THERE in the sequence.
What i mean is, on playback, the clip looks corrected, and suddenly, the last 2 frames are not corrected. Even happens when I go frame by frame on playback.
If i export, make self contained AND recompress all frames, the color is right... it doesn't drop out.
But why should i have to to do this, and wait for this long export, to get the color showing correctly?
And I'm only using QT player x to view the exports.
Any ideas?
David Roth Weiss
Re: Color Correction drops out part way through clips after export in FCP 6
on Dec 21, 2011 at 3:55:15 am
It sounds as if "Full" may not be checked in the Render All drop-down menu. Check it, then rerender the sequence. Then export as you initially did, i.e. self contained, without checking Compress All Frames.
If the above doesn't work, try using Render Manager to delete all renders, then rerender all.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Don't miss my new Creative Cow Podcast: Bringing "The Whale" to the Big Screen:
http://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfit...
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Ben Knight
on Dec 21, 2011 at 4:54:33 am
Hi David,
You are correct, "Full" was not checked in the Render All Dropdown menu. That alone did not fix the problem, but using the render manager to delete all renders, then re-rendering, DID fix it! At least the culprit clips are fixed. If any other similar probs pop up I'll re-post, but for now.. Thanks! You're a legend.
Ben
David Roth Weiss
on Dec 21, 2011 at 4:42:02 pm
[Ben Knight] "the culprit clips are fixed. If any other similar probs pop up I'll re-post, but for now.. Thanks! You're a legend."
Thanks, I like that Ben... :)
Today is my birthday, so it's a nice day to be a "living" legend - so many only attain the status after they're dead.
Have a great holiday!
David Roth Weiss
Los Angeles
Ben Knight
on Dec 21, 2011 at 11:17:05 pm
Ha ha! Yeah, we like to use the word "legend" with a bit more frequency bit down here (Down Under).... but in this case.. well deserved! Happy Birthday.
Michael Litty
on Oct 14, 2013 at 3:10:12 am
Thank you so much for this. Your brief explanation flipped a switch in my understanding of the render menu that fixed a number of things that were not behaving as I expected.
David Roth Weiss
on Oct 14, 2013 at 3:21:56 pm
You're very welcome Michael.
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
Sales | Integration | Support
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
