Getting "File Error: Access Denied" message when trying to render text
Scott Herriott
on Dec 20, 2011 at 5:05:59 pm
Happy Holidays to all.
Did a simple text superimposition over a slug and it won't allow me to render it. Getting "File Error: Access Denied" message. Had similar problem yesterday with rendering an mp3. David and Shane gave good advice and suggested transcoding song to aiff format but the inability to render problem is still persisting in this sequence.
Any help appreciated.
Thanks in advance,
Scott
Chris Borjis
Re: Getting "File Error: Access Denied" message when trying to render text
on Dec 20, 2011 at 5:56:38 pm
is it an image or text generator?
Scott Herriott
on Dec 20, 2011 at 6:01:26 pm
I'm using the "Text" which is available down in the lower right hand corner of the Viewer pane and is part of a dropdown menu. I type the text in the "Control" window section of the Viewer pane. Sorry for my ignorance on this.
Chris Borjis
on Dec 20, 2011 at 7:24:12 pm
if you're sure thats causing it, copy the text from it and use the "Boris 3D" titler instead.
that one works much better.
