Rendering out of Color to FCP7 then Export with Compressor (H.264) = artifacts
Daniel Neutzsky-Wulff
on Dec 18, 2011 at 9:28:23 pm
We shot a short film with a Sony F-3 camera and did the editing in FCP7 and colorgrading in Apple Color, after sending it back to FCP everything looks fine, but as soon as i convert it to H.264 or any other delivery format i experience artifacts and noise, little blocks and stuff.
Everything was converted to Apple Prores 422 (HQ) before editing, with the correct resolution and framerate.
What's going on?
Dave LaRonde
Re: Rendering out of Color to FCP7 then Export with Compressor (H.264) = artifacts
on Dec 18, 2011 at 11:22:23 pm
Did you adjust the bit rate of the H.264?
Did you export a self-contained QT from FCP for use in Compressor?
Dave LaRonde
Sr. Promotion Producer
Rafael Amador
on Dec 19, 2011 at 3:07:07 am
Make sure that you set the "Frame Control: ON" in compressor.
Rafael
http://www.nagavideo.com
on Dec 20, 2011 at 12:52:58 pm
I just tried that, same result, still blocks and artifacts.
on Dec 20, 2011 at 12:24:58 pm
I used the standard settings that came with the preset.
Yes, I exported a self-contained QT from FCP, which looks fine.
