12 to 16 Bit
John Borowski
12 to 16 Bit
on Dec 18, 2011 at 1:38:39 pm
Hi all,
In my wisdom I have shot talking heads at 12 bit. Capturing to FCP an error warning appears saying sample rates do not match resulting in lip sync being off. Looked in Audio settings - capture settings - dohhhhh??
Help!!!!!! jjb
Steve Eisen
Re: 12 to 16 Bit
on Dec 18, 2011 at 5:07:58 pm
Compressor or QuickTime Pro
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
John Borowski
Re: 12 to 16 Bit
on Dec 19, 2011 at 9:12:32 am
Steve Hi, good to hear from you.
Forgive my lack of knowledge but I cannot understand your reply. I have shot the work on a Canon XL2 with the audio setting on 12 bit. when I try to capture the work with FCP an error message saying the bit settings differ between the camera and FCP which will result in sync being out.. So, my thought was if I could change settings on FCP to capture in 12 bit that would solve my problem, or is this not the way to go. regards jjb
Rafael Amador
Re: 12 to 16 Bit
on Dec 19, 2011 at 6:30:25 am
[John Borowski] "In my wisdom I have shot talking heads at 12 bit. "
What means that?
Have you shot with an ALEXA?
rafael
http://www.nagavideo.com
Bouke Vahl
Re: 12 to 16 Bit
on Dec 19, 2011 at 9:07:34 am
nope, 12 bit 32 Khz 4 channel sound, thus probably on DV.
But i don't see why that should have impact on sync though...
Bouke
http://www.videotoolshed.com/
smart tools for video pros
John Borowski
Re: 12 to 16 Bit
on Dec 19, 2011 at 9:08:09 am
Raffael, many thanks for the reply.
Camera Canon XL2 audio set at 12 bit.
Capturing to FCP error message says device settings differ from capture settings therefor lip sync off
How can I change the settings to receive 12 bit ?
regards jjb
Steve Eisen
Re: 12 to 16 Bit
on Dec 19, 2011 at 2:11:58 pm
Create an easy setup and capture DV 12bit 32k audio instead of 16 bit 48k.
Steve Eisen
Vice President
