Log & Transfer footage from P2
Daniel Pinne
on Dec 18, 2011 at 4:49:54 am
Hi Everyone,
So I'm really new to this game and would appreciate anyone's help in as simple terms as possible. I've read a few other forums but have got quite confused and some of the threads seem to go on tangents just when I think I'm about to get the answer.
Anyway, I'm currently using FC Pro 6.0.6 and I've previously successfull log & captured footage from a P2 card using the instructions that from a previous post on here.
I've gone to log & capture some other footage using the same steps, but the folders appear empty with no clips in them. I'm positive there is footage in there, but the Log & Capture window will not read the clips correctly. I haven't changed any significant settings from the previous import so I'm confused as to why it won't read it correctly. Can someone please help? I've attached a screen shot below that shows the folder '151211' with no clips in it. It should have at least 2 decent size clips in it.
Any help would be appreciate, thanks in advance.
Shane Ross
Re: Log & Transfer footage from P2
on Dec 18, 2011 at 10:42:07 am
Are you sure? Look in the VIDEO folder in the CONTENTS. Are there files in there? If so, is the full card structure intact? Anything in the OTHER folders? Without a fully intact card structure, FCP cannot see a thing.
Shane
Little Frog Post
Daniel Pinne
on Dec 18, 2011 at 10:10:45 pm
Hi Shane,
The Audio, Clip, Icon & Video files all have files in them. The Icon folder shows me that it's definitely the footage that I'm after.
Any other thoughts?
Shane Ross
on Dec 19, 2011 at 7:30:49 am
Well, is the footage AVCIntra like John mentioned?
Shane
Little Frog Post
John Heagy
on Dec 18, 2011 at 7:27:10 pm
Is this DVCProHD or AVC-I P2? If AVC-I you will need to install the Panasonic AVC-I codec. FCP 6 doesn't support AVC-I out of the box.
John
