QuickTimeX h.264 color distorts colors!
Ariel Brener
on Dec 15, 2011 at 3:08:23 pm
I have ran in to a weird problem!
I often export using h264.
When I run a h264 file with QT X it distorts the colors
When I run the same file with QUICK TIME 7 or vlc it works with the right colors
Is this a common thing? Why is it happening? is there a way to fix it?
Is the problem in the file or in the player?
here are some examples
https://img.skitch.com/20111215-qgmbm5gc7griguws24pk477eg3.jpg
https://img.skitch.com/20111215-fjpf9p1f9tu9s43fxngkymntrw.jpg
Shane Ross
Re: QuickTimeX h.264 color distorts colors!
on Dec 15, 2011 at 4:26:18 pm
Quicktime X is still in development. It stinks. I don't use it.
Shane
Little Frog Post
Ariel Brener
on Dec 17, 2011 at 9:17:17 pm
But will my clients see that in this dreadful way? is there a way to ensure it will look good also on QTX?
________٩(̾●̮̮̃̾•̃̾)۶________
New Rig (Leopard 10.5.7):
Final Cut Studio 3
CPU: Core i7 920
RAM: 12gig
GPU: GTX 285 2GB OC
HDD: 6 X 1 TB HDDs: 4 HDDs in RAID-5 and 2 HDDs for System.
OLD RIG (Win Vista Ultimate 64bit):
ADOBE MASTER COLLECTION CS4
RAM: 8GB (Corsair 800Mhz)
CPU: Intel Quad Core 2.4Ghz (Q6600)
GPU: ATI x1950XT 256MB
MB: Asus P5K Deluxe WiFi-AP
Shane Ross
on Dec 18, 2011 at 10:34:08 am
You have no control over what your clients view your final output on. All you can do is insure that you make it look the best it can possibly look. If they use substandard players, it's on them, not you.
I make shows for broadcast. Online and color correct too. I do so with a nicely calibrated broadcast monitor...I make it look the best I can using that. I output a tape, or a full res file for delivery to the networks. Then it is compressed for air, and then broadcast, and played on any number of HDTV (or normal TV) sets. If the person watching...if say my producers were watching on a horrid little HDTV, they might complain. But then I show them the master and say "this is what I gave them. How it is compressed, and what device you use to watch it is out of my control."
Shane
Little Frog Post
Ariel Brener
on Dec 18, 2011 at 11:19:52 am
thank you very much.
Final Cut Studio 3
CPU: Core i7 920
RAM: 12gig
GPU: GTX 285 2GB OC
