RGB TO CMYK problem
Ricky Milling
RGB TO CMYK problem
on Dec 13, 2011 at 6:23:25 pm
Rite i have a problem. I am being given eps files that have a transparent background, theand they need to be put in to Final Cut Pro. I know that CMYK doesnt work in FCP so that they have to be in the RGB spectrum, however when i convert them, their values change and as they are clients specific logos i cannot change them. Is there ay way for me to match the CMYK colours in RGB or any way around this problem.
Dave LaRonde
Re: RGB TO CMYK problem
on Dec 13, 2011 at 7:06:48 pm
The best way is to explain to the client that when YOU convert their CMYK files to RGB, the colors are changing and could the client's artist please make the changes to preserve color integrity.
Incidentally, what are you using to convert the EPS files? The same version of Illustrator that created the files? Something else?
Dave LaRonde
Sr. Promotion Producer
© 2018 All Rights Reserved
