Mastering DVCPro50 sequence via AJ-HD1400
Brian Boyle
on Dec 12, 2011 at 7:54:32 pm
First, a caveat; it's literally been a decade since I have had to master to tape. I've also never mastered to tape using a Panisonic deck. So, here we go:
I have a 720x486 sequence that plays back just fine on my Mac.
On the deck I've tinkered with system settings, frequency settings, etc. and have not been able to lay off the movie via 1394. I can capture and record in 108060i just fine, but no love at lower resolutions.
Can anyone take me through the menu settings (from factory reset) on the deck to get it to record at DVCPro50? Also, do I need to be recording specifically to a DVCPRO50 cassette (blue lip)?
Many thanks for any help.
b
Dave LaRonde
Re: Mastering DVCPro50 sequence via AJ-HD1400
on Dec 12, 2011 at 8:17:26 pm
I don't know about mastering to a DVCPro 50 deck via firewire, but I do spot a problem: the resolution for the codec is 720x480, and not 720x486. It might be the thing that's impeding your progress.
Dave LaRonde
Sr. Promotion Producer
Chris Tompkins
on Dec 12, 2011 at 9:11:03 pm
You can layoff DV50 to that deck.
What are your full sequence settings please?
Chris Tompkins
Video Atlanta LLC
Brian Boyle
on Dec 13, 2011 at 5:12:42 pm
attaching captures from sequence settings.
Chris Tompkins
on Dec 13, 2011 at 5:55:13 pm
ya, the 486 thing, I don't know for sure.
DV50, Like Dave mentioned is 480.
But, in the deck menu settings, you'll need to set the FW input/recording settings to DV50.
Do you have deck control via the 1394?
Chris Tompkins
Video Atlanta LLC
David Roth Weiss
on Dec 13, 2011 at 6:19:18 pm
[Chris Tompkins] "ya, the 486 thing, I don't know for sure.
DV50, Like Dave mentioned is 480."
Yep! That's an important setting that needs to be changed. DV and DVCPro50 are both 720x480.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Don't miss my new Creative Cow Podcast: Bringing "The Whale" to the Big Screen:
http://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfit...
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Brian Boyle
on Dec 13, 2011 at 6:34:32 pm
I do have 1394 control.
question about menu item 023-I assumed PB referred to PLAYBACK FORMAT and wouldn't influence RECORD format. Am I mistaken about that.
Also, what's with this REC INH I can't override? I am trying to use DVCPRO (yellow lip) stock. Am I correct that I can only record DVCPRO50 from FCP onto specifically DVCPRO50 tape stock (blue lip), or will DVCPRO50 record to standard DVCPRO (yellow lip) tape stock?
Finally, why didn't Panasonic hire a copyeditor for their manual? DVDPRO?
Chris Tompkins
on Dec 13, 2011 at 6:41:28 pm
So make a new sequence, and make it 720X480 - DV50.
Copy the other sequence files into it.
See if you can print to tape.
Yellow tape will record dv50.
Chris Tompkins
Video Atlanta LLC
Brian Boyle
on Dec 13, 2011 at 6:46:20 pm
to clarify, deck settings should be:
023 0002
025 0000
892 0000
yes?
Herb Sevush
on Dec 13, 2011 at 8:09:50 pm
[Chris Tompkins] "You can layoff DV50 to that deck."
Are you sure about that? I thought DV50 was playback only on that deck.
Herb Sevush
Zebra Productions
nothin' attached to nothin'
"Deciding the spine is the process of editing" F. Bieberkopf
Chris Tompkins
on Dec 14, 2011 at 3:35:38 pm
No, I'm not sure.
See Image:
It would appear it does not.
See Image:
Sorry, I thought it did.
Chris Tompkins
Video Atlanta LLC
Brian Boyle
on Dec 14, 2011 at 5:53:28 pm
Thanks all. Came to this same conclusion yesterday. will be outsourcing the master to a house with the appropriate equipment.
Thanks for being willing to jump in with me on this problem!
