Flickering Problems
Christopher Targia
Flickering Problems
on Dec 12, 2011 at 7:25:30 pm
So I received some footage from China, shot on XDCAM, 1080HD 30fps, and I'm getting extreme amounts of flickering, is there an easy way to fix this? A good filter or something? Re-shooting is not an option.
Flickering Problems
MacPro Octo Core Intel Xenon 2.8Ghz 10GB DDR2 Ram
FCP 7.0.3
-I highly recommend el Gato Turbo264HD-
Shane Ross
Re: Flickering Problems
on Dec 12, 2011 at 7:48:27 pm
China is a PAL country...everything is 50hz based, including electrical...and lighting. So the lights are on a different hz rate than your camera (that is 60hz)...so you will get flickering.
Not sure if there is a way to fix this...
Shane
Little Frog Post
Chris Tompkins
on Dec 12, 2011 at 9:13:56 pm
Ya, that's a mess, Like Shane said, don't know about a fix.
Was this shot from someone from another country? NTSC 60hz land?
Chris Tompkins
Video Atlanta LLC
Christopher Targia
on Dec 13, 2011 at 2:04:56 pm
this was shot in china by people in china, however they shot it in 30fps without adjusting the shutterspeed
FCP 7.0.3
Steve Eisen
on Dec 13, 2011 at 2:36:07 pm
They should have shot at 50/25.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Christopher Targia
on Dec 13, 2011 at 7:30:13 pm
well regardless of what they should have shot, they shot in 30 because they were handing off the video to Americans; that does not help me fix what I have not though.
FCP 7.0.3
Dave LaRonde
on Dec 13, 2011 at 5:10:58 pm
In the past I've seen third-party plugins mentioned that can help -- but not eliminate -- such light flicker problems. I don't recall what they were called. You'd have to do a search on this forum.
Unfortunately, it'll take a long time because you'll need to use the search term, "flicker". People tend to describe anything from incorrect interlacing to juddder to bad credit rolls as flicker.
Dave LaRonde
Sr. Promotion Producer
Gary Milligan
on Dec 13, 2011 at 5:33:38 pm
[Christopher Targia] "So I received some footage from China, shot on XDCAM, 1080HD 30fps, and I'm getting extreme amounts of flickering, is there an easy way to fix this? A good filter or something? Re-shooting is not an option."
Maybe this Boris FX filter will help.
http://www.borisfx.com/videos/BCCAE/Flicker-Fixer.php
HTH
Gary
This is me - this is what I do - http://web.mac.com/garymmw
