Picture jumps first frame of fade
lucas cheadle
on Dec 10, 2011 at 10:55:57 pm
FCP 7.0.3
Mac Pro 2.66 Quad
OS 10.6.8
ProRes LT timeline
Fully rendered timeline yet there persists a picture jump the first frame of a fade out to black. I've tried keyframing an opacity fade, a crossfade to black, a slug on top of the video track fading in to black... to no avail.
Neil Patience
Re: Picture jumps first frame of fade
on Dec 12, 2011 at 2:17:46 am
It appears you have tried most options in making a fade and are still seeing the pronlem.
I would first remove the fade to see if the picture still jumps. Is there a rogue motion keyframe at the fade pont ?
What happens if you fade a couple of frames earlier or later ? Does the problem persist ?
What happens if you replace the shot with any other and fade that at the same point - does that produce the same jump ?
Those things should give you a clue as to the cause.
best wishes
lucas cheadle
on Dec 14, 2011 at 6:36:31 am
Thanks Neil-
Those were some good troubleshooting tips but nothing changed. Without the fade there's no jump. There were no rogue motion keyframes. When I moved the fade around (location and duration) some weird things happened. The video would flash back to a moment earlier in the clip for a few frames and then return. I've seen that before a couple of times in FCP history and chalk it off to some reference hiccup. Anyways... the work-around I used was to export the timeline without the problem end fade and bring that self-contained mov back into FCP and then add the end fade. Success.
Side note: My source footage was a 720p download from Youtube (h264) transcoded to Prores in MpegStreamclip. Maybe this helps explain the jumpy fade.
© 2018 All Rights Reserved
