MC6 AMA Re-LInk using Automatic Duck FCP Export Plugin
Greg Jones
on Dec 8, 2011 at 4:18:15 pm
So I'm new to Media Composer 6. I used the Automatic Duck AAF export plug-in from FCP to create a AAF Sequence. I checked the 'Use AMA Relink' option. When I open the project in Media Composer, all the clips and sequence show up in my bin. They are, however, offline. I've tried every setting combination using 'Relink' that is possible but I always get an error saying 'Clips were not relinked'. I'm sure I'm doing something simple but just curios if anyone uses this function regularly and how they do it.
Greg Jones
D7,Inc.
Orlando,Fl.
http://www.d7-inc.com
Dave LaRonde
Re: MC6 AMA Re-LInk using Automatic Duck FCP Export Plugin
on Dec 8, 2011 at 4:49:41 pm
Are FCP, The Duck and Media Composer all on the exact same computer?
Dave LaRonde
Sr. Promotion Producer
Greg Jones
on Dec 8, 2011 at 5:33:03 pm
Yep
Mark Spano
on Dec 8, 2011 at 5:34:35 pm
Sometimes in order for this to work, you have to make a new bin, drag all of the AMA clips and all of the 'ducked' clips in. When they're all in the bin, then you can select them all and relink based on current selection. Or relink based on AMA file name, or something like that. It takes a lot of playing around like this to get AMA clips to link to 'ducked' clips, but it does work.
Alex Elkins
on Dec 8, 2011 at 6:07:22 pm
I'm fairly new to Avid too, and had exactly this problem earlier this week. I managed to track down the Avid document below, which solved it for me.
3386_amarelink.pdf.zip
Alex Elkins
Twitter: @postbluetv
http://www.PostBlue.tv
View Post Blue showreel
Shot on RED @ 100fps, Post on FCP/Color: Capoeira Film
My Vimeo Pro page
Neil Patience
on Dec 8, 2011 at 8:45:39 pm
Thanks for posting that - I had the exact same issue, luckily was just experimenting but that is a very useful document
Thanks again
best wishes
Neil
http://www.patience.tv
