Timecode issue on "Capture Now"
Sebastian Lloyd
on Dec 8, 2011 at 2:01:38 pm
Hi all, this is a weird one.
We're doing Capture Now on HDCam, downconverting to SD, with it set to create a new clip on each timecode break.
Most clips are coming in with the correct timecode, but a few per tape are coming in with a timecode starting at 00.00.00. The timecode is showing up correct in the deck and in log&capture, but it's resetting to zero when it's actually brought in.
Re-capturing the entire tape replicates the problem with the same clips having timecodes reset.
Can anyone shed any light? Daytime TV depends on it!
Cheers,
Seb
mircea dobre
Re: Timecode issue on "Capture Now"
on Dec 11, 2011 at 11:45:06 am
hi,
It might be from the tapes. check the timecode from the camera when the timecode reset appear on the computer.
Good luck,
