Media Manager: proxie/rendered file switch causes frame size change
Akash Kumar
on Dec 7, 2011 at 10:29:06 pm
Hey there. Long time lurker, first time poster.
So I shoot/edit music videos and I started using a workflow that starts off with Magic Bullet Grinder. Make my proxies and rendered 422 files. Then I edit with the proxies in Final Cut. Then I use media manager to disconnect the files and create a new sequence. Then when I reconnect with my rendered files it tells me that there may be changes and it pretty much zooms the fame in a whole 1/3 for each clip.
I shoot with a 5D Mark II. Got a deadline on this video in two days. Please help! Thanks.
Nick Meyers
Re: Media Manager: proxie/rendered file switch causes frame size change
on Dec 9, 2011 at 9:09:11 pm
when you "Create Offline" in Media MAnager,
remember to "set Sequences To" the format of your camera original,
or at least a Prores sequence that has he same frame size & pixel aspect.
nick
