Turn a SD video into HD
Jay Fishback
on Dec 7, 2011 at 3:31:21 pm
So i know you cannot turn SD footage into HD footage automagically as Dr. Tuneup (Biz Markie) would put it, but the footage was originally recorded on a 5D and coded through compressor into DV NTSC. I know I should have initially coded it into ProRes, but at the time I couldnt afford the extra space on my harddrive. So I know pretty basic things about final cut (a photographer in a moving world) but is there a way to time stamp the clips so all I would need to do is code the correct footage into ProRes and then walla its there. I have FCP 7.
Here is a link in case you are interested.
Mark Suszko
Re: Turn a SD video into HD
on Dec 7, 2011 at 3:40:10 pm
You use Media Manager to re-import the high rez footage matching what you've edited, and if everything works as it si supposed to, you should end up with the same edit in HD.
Jay Fishback
on Dec 7, 2011 at 3:45:01 pm
Thanks Mark. I will do that.
