Sequence setting problems
Erick Stoll
on Dec 7, 2011 at 5:07:06 am
I had an assistant editor organize some interviews for me shot on the ex1 and brought into FCP natively using the calibrated plugin. When I got her project files, her sequence settings are all wrong--the aspect ratio is 1440x1080, and the pixel aspect ratio is too. For the XDCam timeline, the aspect ratio is 1920x1080, and the pixel aspect ratio is Square.
The problem is, when I copy over the footage in her timeline to mine, the aspect ratio is wrong, with the video squished into a square inside a widescreen frame. Likewise if I try to change her sequence settings to meet mine.
I hope I explained this clearly enough. Is there any solution to this, or does her work need to be redone?
David Roth Weiss
Re: Sequence setting problems
on Dec 7, 2011 at 5:15:30 am
Select all the clips that are distorted, right click, select Remove Attributes, check the Distort checkbox, and hit okay.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Don't miss my new Creative Cow Podcast: Bringing "The Whale" to the Big Screen:
http://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfit...
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Erick Stoll
on Dec 7, 2011 at 1:26:26 pm
Thanks! I just might make deadline now!
Rafael Amador
on Dec 7, 2011 at 6:48:22 am
[Erick Stoll] "I had an assistant editor organize some interviews for me shot on the ex1 and brought into FCP natively using the calibrated plugin. When I got her project files, her sequence settings are all wrong the aspect ratio is 1440x1080, and the pixel aspect ratio is too. For the XDCam timeline, the aspect ratio is 1920x1080, and the pixel aspect ratio is Square. "
They have shoot XDCAM SQ instead of HQ, which means plain HDV (1440x1080 HD pixels).
Is correct to edit that on a 1920x1080 SQ pixels (Prores better).
You should set your sequence the same and fallow David advise (Remove attributes> Basic Motion + Distort). The footage will fit in the canvas screen.
rafael
http://www.nagavideo.com
