Final Cut Pro EDL Export Problem
Omer Ozcan
on Dec 6, 2011 at 1:26:21 pm
Hello,
I am trying to get an edl of my movie. when i export edl, it appears everything is correct except the ends of clips are one frame more than original. how can i fix it?
thank you.
Andrew Rendell
Re: Final Cut Pro EDL Export Problem
on Dec 6, 2011 at 1:45:52 pm
It could be that you're misreading the edl. The convention for edl's is that the IN point is the first frame recorded on the "master tape" and the OUT point is the first frame not recorded, so each edit will have the same number in the OUT point as the IN point for the next edit.
