red render bar
Sofie Flamand
red render bar
on Dec 6, 2011 at 6:13:14 am
I have been editing using the same settings in FCP for over a year and now I am suddenly getting a red render bar. The project I am working in is pretty big - could that have something to do with it?
I always put all clips through the same compressor settings - so I don't end up with clips which do not match.
25fps, frame size 1920x1080, data rate 4.4Mb sec, pixel aspect square, audio rate 48KHz
I have checked and re-checked that the clips have exactly the same aspects video / audio - and as I said I have always used the same compressor on all clips and never had this problem before.
Now I get a red render bar when I stack clips and / or use text boxes (without drop shadows etc) - so my question is - can this be because the project is too big?
I also want to add that I am working on a completely new Mac OS X (8GB)
Any ideas as tho what is causing the red bar - and how to fix it is greatly appreciated
Many thanks in advance
Rafael Amador
Re: red render bar
on Dec 6, 2011 at 3:40:29 pm
[Sofie Flamand] "I always put all clips through the same compressor settings - so I don't end up with clips which do not match.
25fps, frame size 1920x1080, data rate 4.4Mb sec, pixel aspect square, audio rate 48KHz"
Which codec?
What kind of footage?
rafael
http://www.nagavideo.com
Dave LaRonde
Re: red render bar
on Dec 6, 2011 at 8:20:58 pm
[Sofie Flamand] "I also want to add that I am working on a completely new Mac OS X (8GB)"
...and if you did not do a clean install of the OS and application software, this is the root of your problem. Here's a a tale of woe similar to yours:
http://forums.creativecow.net/thread/8/1148896
Dave LaRonde
Sr. Promotion Producer
Tom Matthies
Re: red render bar
on Dec 7, 2011 at 8:46:05 pm
Playback settings? Safe or Dynamic?
E=MC2+/-2db
