FCP Capture Blues - Sony J-H1 HDCam Deck
Andy Gallun
on Dec 5, 2011 at 5:40:46 pm
Trying to get FCP 7.0 to recognize an old Sony J-H1 HDCAM deck. I've played with the Capture/Device Control settings with no avail. Changed cables and different firewire (400 vs. 800) ports on the computer, also with no luck.
Any thoughts?
Someone told me that you can only capture SD out of the firewire port on this deck. Is there any truth to that? At this point I will take SD over nothing, but the full HD would be better.
The following is the info on the computer that we are trying to capture to:
Model Name: Mac Pro
Model Identifier: MacPro3,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.8 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 12 MB
Memory: 8 GB
Bus Speed: 1.6 GHz
Boot ROM Version: MP31.006C.B05
SMC Version (system): 1.25f4
Thanks in advance for your help!
Andy
Andrew Gallun
Sleeping Dog Productions
http://www.sleepingdogtv.com
The Leader In Aviation Television Production
Fred Miller
Re: FCP Capture Blues - Sony J-H1 HDCam Deck
on Dec 5, 2011 at 6:02:17 pm
You may have to turn on the firewire connection on the deck through the menu on the deck. I think it's called i.LINK. I don't know for sure, but I'm guessing that you are correct about SD only through the firewire.
FCP Studio 2
Dual 3Gg Quad Core
4Gg RAM
KONA 3
OS 10.5.8
Shane Ross
on Dec 5, 2011 at 6:33:53 pm
Via firewire you will only get DV, as a matter of fact. The lowest format of SD. And you won't get deck control...only a video signal. So it will have to be an UNCONTROLLED DEVICE setting for this, and you'll have to manually control the deck.
Shane
Little Frog Post
Shane Ross
on Dec 5, 2011 at 6:34:21 pm
And you might have to look in the settings to make sure that DV is set up to go out via firewire. It might default to it...but need to be sure.
Shane
Little Frog Post
Andy Gallun
on Dec 5, 2011 at 8:47:30 pm
Thanks much for the replies. I was able to get deck control, but only with a 720x480 output. Looking into an internal capture card with component connections to get around this.
Andrew Gallun
Steve Eisen
on Dec 6, 2011 at 1:40:35 am
Capture i/o devices from Matrox, AJA and Black Magic are so affordable these days. Everyone should have them. You can even monitor your timeline via inexpensive LCD TV's.
External units you can use on both the Mac Pro and Mac Book Pro (firewire 800 or Express 34) and PCIe units just for the Mac Pro.
With Thunderbolt units, you can connect to MBP and iMac.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Andy Gallun
on Dec 7, 2011 at 12:02:51 am
Anybody have any experience with a BlackmagicDesign DeckLink Studio card? Looks like it will give us the ability to capture the HDCam tapes in true HD via component connections.
Andrew Gallun
Shane Ross
on Dec 7, 2011 at 12:08:21 am
[Andy Gallun] "Anybody have any experience with a BlackmagicDesign DeckLink Studio card?"
Yes.
[Andy Gallun] " Looks like it will give us the ability to capture the HDCam tapes in true HD via component connections."
It will.
Shane
Little Frog Post
