Serial Number will not load, FCP-7
Nate Stephens
on Dec 4, 2011 at 9:18:58 pm
I am loading a brand new copy of FCP-7, got a volume type job and purchased three copies from the Apple Store. I was loading a copy on our (Office work-under powered)) Mac Pro 2.8 Quad core, 4 gb ram. I have done two complete installs and then FCP must go out to the network and grabs the first FCP serial code it can find, not giving me a chance to load the new serial code. Of course then when you try to run FCP it finds the other FCP copy running and we get a conflict.
Does anybody know where the serial number is stored and the process for changing the serial number to the right serial number?
Thanks for your replies.
Nate
FCP, Mac Pro, Mac Book Pro, HPX500, HVX200, Betacam, Dvcam
Write for the Edit, Shoot for the Edit, Edit.....KISS Principle
Steve Eisen
Re: Serial Number will not load, FCP-7
on Dec 4, 2011 at 11:59:53 pm
Mac HD/Library/Application Support/ProApps/Final Cut Pro System ID
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Steve Eisen
on Dec 5, 2011 at 12:02:38 am
Delete the Final Cut Studio System ID and relaunch FCP.
Steve Eisen
Vice President
Nate Stephens
on Dec 5, 2011 at 1:38:14 am
Steve,
Thanks for the reply. I found this answer from Jerry Hoofman in the Cow archives.
And no luck at all with just deleting the FCP Studio System ID. After two more total reloads I got brave and deleted the Pro Apps system ID from the same folder and oh my it worked as advertised and let me enter a new serial number. It is the Pro Apps System ID delete that did the trick. We should update the archives on this nasty Sunday afternoon time burner.
Thanks for being there with a reply.
nate
