SD interlaced footage to be shown via laptop/projector - how to convert?
Mike Thomas
on Dec 3, 2011 at 5:47:15 am
I have a feature documentary that we are showing in schools. It was shot in SD PAL interlaced, but most schools screen it with a laptop and projector. I've noticed that the quality suffers, predominantly when there is motion in the picture. This doesn't happen when played through a conventional DVD player. Also the subtitles are blocky when played back on a computer.
I'm assuming this is something to do with interlaced v progressive formats. Could anyone advise how I should compress the output to achieve a higher quality if using a laptop for screening? Thank you so much
Jerry Hofmann
Re: SD interlaced footage to be shown via laptop/projector - how to convert?
on Dec 3, 2011 at 4:27:10 pm
You can deinterlace the footage during compression, try that. I'd probably use h.264 at a high bit rate, don't change the frame rate, nor change the size.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
