Powerpoint jpgs importing as HD in an SD project
Leonard Frankford
on Dec 2, 2011 at 9:17:03 pm
Everytime I create an SD project and need to import Powerpoint slides converted to .jpg, the images come into the browser and canvas in the stretched HD aspect ratio even though my sequence is SD, 720x480. Anamorphic is unchecked in the Browser. I have to apply a Distortion effect to each slide in the timeline to fix this. Is there some way to fix this in the Preferences or Browser so that they come in 4x3 to start with? Thanks.
Leonard
Leonard F.
Jerry Hofmann
Re: Powerpoint jpgs importing as HD in an SD project
on Dec 3, 2011 at 4:30:50 pm
I should think that this is a setting you need to make in the export from power point... can't change the format of a media file once made elsewhere just by some sort of setting in an import routine.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
