60fps> conformed 25fps slo-mo> 25fps real time??
Jim Simpson
on Dec 1, 2011 at 7:42:21 pm
Hi, I have some footage that was shot at 60fps that was then conformed to 25fps (PAL) with Cinema Tools to playback in slow motion. Now the producers want to see what this footage looks like at 25fps in real time, as if it was originally shot at 25fps.
What is the easiest way to convert this footage back to 25fps? I was thinking the easiest would be to simply speed it up by a certain amount in the timeline, does this sound right?
Jim
Dave LaRonde
Re: 60fps> conformed 25fps slo-mo> 25fps real time??
on Dec 1, 2011 at 9:48:56 pm
Did you save a 60 fps copy? Hope so! If not, duplicate the footage, conform to 60 fps and use Compressor to convert to 25 fps. It should do an adequate job.
Dave LaRonde
Sr. Promotion Producer
