Flicker problems with digitized super 16mm film
Emily Needell
on Nov 30, 2011 at 11:25:52 pm
Hello,
So I have a bunch of digitized super 16mm film that I am editing in FCP. However, in some of the shots, there is a weird flicker (this is AFTER using Cinema Tools to reverse Telecine, or de-interlace, the footage). I tried using FCP's flicker filter, but to no avail.
Any suggestions? Is there another flicker filter I can use?
Emma
Brad Wright
Re: Flicker problems with digitized super 16mm film
on Dec 1, 2011 at 1:51:15 pm
Are you seeing this problem on a external monitor that is interlaced? If you step frame by frame are you seeing this flicker? Try removing the Telecine in Compressor. Drag your file into compressor and select a ProRes codec encoding option. Click on the frame control tab. Turn on frame control. Under de-interlace click the popup button and set it to Reverse Telecine. Give that a shot.
Brad Wright is software engineer, so it may be difficult to understand what he is saying. He is always happy to explain his greater detail.
