audio file volume lowering
Zoe Weslowski
on Nov 30, 2011 at 8:04:05 pm
I was working with a few clips in the time line - just experimenting with some effect changes with Image Control - negatives and color reduce...and suddenly my audio became lowered. I did not make any changes to the audio track at all. I could not determine where this was, so I close the file not saving changes and when I reopened the volume was at the same level as previously. I find this odd since I did not make any changes at all to the audio file.
Dave LaRonde
Re: audio file volume lowering
on Dec 1, 2011 at 5:10:56 pm
AE likes AIFF audio at 48kHz. 16 or 24 bits. If the audio tracks of your clips don't take that form, you could have problems.
Dave LaRonde
Sr. Promotion Producer
Zoe Weslowski
on Dec 2, 2011 at 6:13:01 am
Hmm. But it was weird because I didn't change anything and everything was working fine before...then suddenly changed. So I closed out, reopened and the volume was normal again. This time I locked the audio track...
