final cut pro wont load
Mike Brannagan
on Nov 30, 2011 at 2:03:11 am
Just bought a new studio 2
I am attempting to load on a used Mac Pro
Former owner had adobe products and pro logic loaded
I am getting a notice saying Final cut pro quit unexpectedly while using the
NAU_OxfordDynamics plugin
Jerry Hofmann
Re: final cut pro wont load
on Nov 30, 2011 at 2:06:41 am
I'd suggest a clean install. Erase your startup disk, and install OS et all from the ground up.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Mike Brannagan
on Nov 30, 2011 at 2:10:27 am
Thanks makes a lot of sense
Regards
Jerry Hofmann
on Nov 30, 2011 at 2:11:51 am
Well, at least that way, you know you're starting over as if the machine were new sort of... except the hardware is used.
Jerry
Current DVD:
