Speed changes for effect
Gavin Williams
on Nov 28, 2011 at 7:50:53 pm
So we filmed a music video - the musician mimed to the track which we slowed by 10%. We then speeded it up by 10% in Final Cut (so clip was at 110%). We thought that would match back up with the proper spped of the track but it doesn't seem to sync up. We filmed at 24fps?? What are we doing wrong??
Neil Patience
Re: Speed changes for effect
on Nov 28, 2011 at 8:55:52 pm
Ok I could be wrong but I dont think your maths quite works,
If the original speed was 24 and you slowed by 10% then your frame rate was 24fps - 2.4fps = 21.6 fps
However if you speed up 21.6 by 10% you get
21.6fps + 2.16fps = 23.76 fps
I think you need to speed up by 11.111111% to get back to 24fps.
Then again my maths is rubbish too but seems to add up ??
best wishes
Neil
http://www.patience.tv
Gavin Williams
on Nov 28, 2011 at 9:10:46 pm
Thanks for the comeback
So even though I filmed it in 24FPS and the band just played it slower FPS is still a factor? Wow this is hard to get your head around eh!
Gonna try your maths
Thanks again!
Neil Patience
on Nov 28, 2011 at 9:27:04 pm
I have not quite thought this through and to be honest I am still not sure I am right because wont that just get you back to the original speed rather than your desired effect ?
What were you trying to achieve - the video looking slightly slow but obviously maintaining sync ?
I am not sure you can do this without a corresponding frame rate change in the camera as both need to match.
Doing one without the other doesnt quite work does it ?
best wishes
Neil
