Interlacing artifacts
Michel Salama
on Nov 25, 2011 at 1:09:02 pm
I have a problem with the high movement shots burned on dvd, "lines" appear on the screen..i need to know the exact steps to prevent these interlacing artifacts using MPEG Streamclip like: "Interlaced Scaling" or "Deinterlace Video" " Frame size 16:9 unscaled ,compression type, ect.. what buttoms should i select on..
and also if using final cut time line export..
by the way am shooting 1920x1080 50i
Thanks a lot
Brad Wright
Re: Interlacing artifacts
on Nov 25, 2011 at 4:34:57 pm
If you are trying to create interlaced video on a DVD, then you need this horizontal lines in the video. They don't appear on an interlaced television monitor when resized correctly. I wrote an article on transferring HD footage to DVD for the Los Angeles Final Cut Pro users group that covers all the details of this.
How are you using MPEGStreamclip and with what settings? I don't recommend using MPEGStreamclip, as it's not easy to use and I've found it has a lot of problems.
Brad Wright is software engineer, so it may be difficult to understand what he is saying. He is always happy to explain his greater detail.
Chris Tompkins
on Nov 25, 2011 at 5:31:44 pm
You shoot interlaced.
Your footage is interlaced.
Computer screens don't display interlaced footage properly.
You finished DVD's should look fine played on a DVD player in the Living Room.
Chris Tompkins
Video Atlanta LLC
