New Hard Drive Recommendation for Firewire 800 port
Zack Mulvaney
on Nov 25, 2011 at 5:49:34 am
I've been having some problems with my g-drive, so i'm in the market for a new external hard drive for editing (1TB+). The fastest port my imac has is firewire 800. Any recommendations? Newegg seems pretty thin on options for firewire 800 hard drives, so the help in finding a good option is much appreciated.
Also, I'm just assuming I should go with a firewire 800 hard drive since that's my fastest port -- if anyone disagrees on my amateur thinking here, please do enlighten me.
adam taylor
Re: New Hard Drive Recommendation for Firewire 800 port
on Nov 25, 2011 at 9:19:50 am
I have a Glyph Portagig62 - which is very good. Its a small portable raid made with 2x 2.5" drives, and it is firewire 800 bus powered.
Its been extremely reliable (i got it to replace a g-raid mini which died after only three power ups!).
I'm very happy with the Glyph.
Adam Taylor
Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
Character Options Ltd
Oldham, UK
http://www.sculptedbliss.co.uk
My YouTube Animations Page
Zack Mulvaney
on Nov 25, 2011 at 9:22:51 am
Thanks for the rec. I'm not sure I need raid, and obviously I'd like to avoid the price tag of raid if possible. Any recs on non-raid?
Brian Vedholm
on Nov 25, 2011 at 9:37:00 am
I use CalDigit VR connected to my IMac with firewire 800. Works for me. Never had any problems.
http://www.stjernholm-media-proshop.dk/product.asp?product=6150
adam taylor
on Nov 25, 2011 at 10:25:50 am
it only costs £180 (not expensive in my book)- and you were asking about firewire800 because its your fastest port - and Raid is typically faster than a single drive.
Raid has two benefits with a drive like this- you can set it one way and get increased speed or set it for security by duplicating the data to both drives.
Adam Taylor
Oldham, UK
Bret Williams
on Nov 25, 2011 at 10:17:18 pm
There is no performance gain with a raid over FW800. A single firewire 800 drive maxes out the data capacity of FW800. These G-Raids and such usually have an esata port, of which you will gain a 30% performance jump just for eSATA, but if you raid it AND use a compatible eSATA card (usually $200+, not the $50 ones) then you can quadruple or more the performance of the drive vs. hooking it up FW800.
