alpha transparency channel export?
fabiola sialer
on Nov 24, 2011 at 4:41:47 am
hello everybody,
i hope someone can help.
i need to export a subtitle video track from a project to a animation .mov with alpha transparency channel included, so i can send it to the post production guy as an individual .mov from the project itself. when i export it to the compressor i can't find a way to create it, just a "normal" animation alpha, and when i import it back to the project in fcp7, black blocks appears when there is no video content (text signal from the subtitles), so it is not possible to work fluently.
is there a correct way to do this, making the subtitles work like a transparency layer? just working with fcp7, compressor or motion, by the way.
thanks in advance!
fabiola sialer cuevas
fcp7 editor
lima
Michael Gissing
Re: alpha transparency channel export?
on Nov 24, 2011 at 6:22:08 am
Animation millions + is the setting for an Alpha channel export. Is this what you are doing?
