No 25Psf capture?
Eugene Lehnert
No 25Psf capture?
on Nov 23, 2011 at 3:12:01 pm
I rarely use 25p material but is there no HD 25Psf capture in Final Cut Pro that isn't 50i? I had to do a job and I had to reset all my clips manually to progressive dominance in the item settings. I never noticed that before. Is this the only way to work in 25Psf progressive?
Rafael Amador
Re: No 25Psf capture?
on Nov 23, 2011 at 4:24:17 pm
[Eugene Lehnert] "I rarely use 25p material but is there no HD 25Psf capture in Final Cut Pro that isn't 50i? I had to do a job and I had to reset all my clips manually to progressive dominance in the item settings. I never noticed that before. Is this the only way to work in 25Psf progressive?"
You select all the stuff in the Browser and change it at once.
rafael
http://www.nagavideo.com
