Nice "warp-speed" transition effect
Eivind Sivertsen
on Nov 23, 2011 at 10:02:19 am
Hi guys,
I've seen this effect around, don't have a name for it, but am wondering how to make it. Here's an example:
It's the transition I'm after; akin to when space ships enter warp speed in some sci-fi movie.
Anyone?
Cheers + best regards;
::e
@ivind
Eivind Sivertsen
Re: Nice "warp-speed" transition effect
on Nov 23, 2011 at 12:03:15 pm
(Oops, forgot to check the notification email option. Checked!)
Mark Suszko
on Nov 23, 2011 at 7:54:28 pm
Apple Motion has some effects like this, match up colors and add some blend modes and I think you can get close.
Eivind Sivertsen
on Nov 23, 2011 at 8:10:41 pm
Any particular effects that you know the name of ? :-}
@ivind
Mark Suszko
on Nov 23, 2011 at 10:52:00 pm
Just open up the browser for the free content, there's a LOT of stuff in there for free.
Phil Smith
on Nov 26, 2011 at 1:44:50 am
Honestly speaking, you can re-create that effect pretty easily in FCP by using "Light Rays" along with the "Dazzle" effect. They are located under the Video Filters > Glow menu.
You can apply the Light Rays effect and keyframe the Mix to 0 at the start of your clip, then keyframe the ramp of the rays over however many frames you want it to transition.
Use Dazzle to give it the over-the-top flash, once again, ramping up the mix to taste. You can then color correct the clip you are using to give you whatever color of rays you want.
Just a thought. ;-)
