FCS 3 upgrade from 2 on Lion or drivers for snow leopard on new iMac i7
Brian Cooney
on Nov 21, 2011 at 11:23:49 pm
purchased a new iMac quad with i7 proc. Firmware is different so I can't install my Final Cut Studio 2 software and then subsequent FCS3 upgrade. I would be happy to install Snow Leopard but tried that and evidently I don't have the drivers. Does anyone have any work arounds for this? Tried partitioning. that won't work. Tried migrating from another computer. Does a Snow Leopard disc image with modified drivers exist out there? - Brian
MotionFoundry, Inc. Video Post
Clients: GM, AOL, Kohl's, 3 Doors Down, Thomas Nelson, NASCAR Affiliates
Neil Patience
Re: FCS 3 upgrade from 2 on Lion or drivers for snow leopard on new iMac i7
on Nov 21, 2011 at 11:32:46 pm
Why do you need to install the FCP Studio 2 version at all? You should be able to use the ugrade FCP Studio 3 version, which will install on Lion, it will first ask you for the FCP 3 serial number, then it will say thats an upgrade enter the serial from the product you are upgrading from.
Type in your original FCP 2 serial and away you go.
best wishes
Neil
http://www.patience.tv
Brian Cooney
on Nov 21, 2011 at 11:53:04 pm
wow I feel dumb. I wasn't aware that the Upgrade DVDs contained all the information in a full install. is this true? thanks
Shane Ross
on Nov 22, 2011 at 12:04:09 am
Upgrade installs are the FULL install. The only difference is the serial number...it requires a previous full version number in order to install.
Don't install previous versions then the upgrade. Just install the latest...have that FCS2 serial number handy.
Shane
Little Frog Post
Neil Patience
on Nov 22, 2011 at 12:04:33 am
Yep its true - have done it many times including 2 Lion installs, clean installs are better in any case.
You just need both serials handy.
best wishes
Neil
