DVCAM files from Sony EX1R import into FCP?
Alexander Wolf
on Nov 21, 2011 at 2:14:15 pm
The XDCam transfer plugin does not allow me to import the files. I can see the BPAV folder but it is greyed out...
When I go straight into the folder outside of FCP, I can see AVI files that play ok in QT but do not have right aspect ratio. (4:3 as opposed to 16:9)
Rafael Amador
Re: DVCAM files from Sony EX1R import into FCP?
on Nov 21, 2011 at 4:21:29 pm
[Alexander Wolf] "When I go straight into the folder outside of FCP, I can see AVI files that play ok in QT but do not have right aspect ratio. (4:3 as opposed to 16:9)"
Hi Alexandre,
That may be just when displayed by QT.
Try importing one of those files to FC and check it as Anamorphic in the Browser to see how it looks.
rafael
http://www.nagavideo.com
Alexander Wolf
on Nov 21, 2011 at 4:43:58 pm
Thanks, Rafael, I just dragged the AVI files into FCP and that's just as you said. But what's the proper procedure for getting XDCAM DVCAM into FCP7??!!
Rafael Amador
on Nov 21, 2011 at 4:52:58 pm
[Alexander Wolf] "Thanks, Rafael, I just dragged the AVI files into FCP and that's just as you said. But what's the proper procedure for getting XDCAM DVCAM into FCP7??!!"
Sorry but no idea. I have an EX-1 and does'n makes SD.
Although that makes no much sense, have you tried L&T?
You can rewrap very easily the AVI as QT (open with MPGStreamclip > SAVE AS..QT. no rendering, really fast), but i guess that may be a pain if you have many clips.
rafael
Alexander Wolf
on Nov 21, 2011 at 6:27:31 pm
Thanks, Rafael. For now it works just dragging them into FCP. I just don't understand why XDXCAM Transfer doesn't work the same as with HD. It's the same folder structure...
Rafael Amador
on Nov 22, 2011 at 3:42:31 am
[Alexander Wolf] "Thanks, Rafael. For now it works just dragging them into FCP. I just don't understand why XDXCAM Transfer doesn't work the same as with HD. It's the same folder structure..."
Yes but the Transfer main purpose is to re-wrap the MP4 as QT or MFX and here there are no MP4s.
Just be careful when you bring the AVI to FCP. he doesn't like too much those files.
rafael
