Audio sync problems
Lachlan Fletcher
Audio sync problems
on Nov 20, 2011 at 8:22:27 am
Hey all. I have an issue that i have seen come up a lot but I haven't found it resolved. I have a project that has pro res LT vision with audio recorded at 48KHz at 16 bit. I am syncing it with .wavs recorded at the same KHz & bit rate as I do on a daily basis. The problem is that this time the timeline runs out of sync & I cannot figure out why. All the settins seem fine ie 48 bla bla....
Any ideas??
Lach
Jerry Hofmann
Re: Audio sync problems
on Nov 20, 2011 at 2:54:01 pm
Try transcoding the WAV's to Aiffs, then syncing.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Michael Gissing
on Nov 20, 2011 at 9:14:24 pm
And read this tutorial, particularly the second half that tells about the correct importing of audio assets so FCP can frame rate stamp the audio correctly. This is such a common problem that this question pops up a few times each week -
http://library.creativecow.net/lyon_matt/fixing-fcp-assets/1
Lachlan Fletcher
on Nov 21, 2011 at 1:10:43 pm
Hey Jerry,
Thanks for the reply. Your right that works I tried it last night as a last resort before I received your post.Im unsure why as 99 times out of 100 its fine but hey..... whatever works!!
Thanks mate
Lach
