FCP and external hard drive troubles
Lindsey Hackney
on Nov 20, 2011 at 2:21:22 am
I was using FCP 6 to edit a video, saving everything to an external hard drive. Everything was going fine until I left my computer for a while and came back to a black screen. Somehow my computer crashed. When I turned it back on and reconnected my external hard drive, this message came up:
"The disk "IMG 500-003" was not repairable by this computer. It is being made available to you with limited functionality. You must back up your data and reformat the disk as soon as possible."
I pressed 'ok' and tried to get into my FCP file which opened easily but when I try to save (using 'save' OR 'save as'), a message pops up saying:
"File Error: The specified file is locked"
I looked at the disk permissions for the external and they are now read-only.
If I repair disk permissions for the external, will I lose all of my work? Is this even the right course of action?
Jerry Hofmann
Re: FCP and external hard drive troubles
on Nov 20, 2011 at 2:44:38 pm
You can't just drag and drop the files from the failing drive to another location? That's where I'd start. Check the copies by opening them.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
David Roth Weiss
on Nov 20, 2011 at 4:32:11 pm
You need to acquire and run Disk Warrior on that drive ASAP, and then get everything off of it. Even if it seems as though it's fine after running DW, I would not trust it. It sounds as if the drive's power supply may be failing.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.com
Don't miss my new Creative Cow Podcast: Bringing "The Whale" to the Big Screen:
http://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfit...
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Lindsey Hackney
on Nov 20, 2011 at 6:33:42 pm
Unfortunately, it's a work hard drive so I have nowhere to move the files (they must go onto this drive and be returned). Looks like I may need to just return the drive for a new one if the power supply is failing?
Thanks for the suggestions.
L. Hackney
Chicago, Illinois
Steve Eisen
on Nov 21, 2011 at 3:16:58 am
I agree with the power supply. If it's not the power supply, Data Rescue from ProSoft may be able to help.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
