incomplete sequence export
Kyle Moore
on Nov 19, 2011 at 3:13:52 am
Hello all,
Yet another last minute problem: I'm trying to export a bunch of different sequences for my boss, one at a time. I've noticed that they are exporting only partially. That is to say only 25 minutes of a 30 minute sequence will render out to a quicktime file.
Does anyone know why this would be happening? I have unchecked the "limit render size" box in system settings so I know that can't be the problem. Also my in and out points are set correctly.
Any help would be greatly appreciated!
Jerry Hofmann
Re: incomplete sequence export
on Nov 19, 2011 at 12:20:28 pm
What video formats are you working with? Source footage was what? Post the sequence settings too.
When you export the video, are you changing formats or?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
