Converting MP4 files from EX1
Ben Carter
on Nov 17, 2011 at 10:47:53 am
Hey there, I've been given a few mp4 files apparently shot on an ex1. I'm trying to find software that will convert them to an .mov I actually thought MPEG streamclip would do this! It's turning out to be quiet a mission...
Does anyone know the straight answer to this question? I know it must be something really simple but I've never worked with these cameras before so please excuse me :D
Thanks in advance.
BC
Rafael Amador
Re: Converting MP4 files from EX1
on Nov 17, 2011 at 3:38:42 pm
Hi Ben,
You need to use the "SONY Clip Browser" application to rebuild a BPAV folder, then use Log&Transfer to rewrap that as a QT file editable in FC.
Other way is to buy the "Calibrated" plugin that will let you edit the MP4 directly in FC.
rafael
http://www.nagavideo.com
Ben Carter
on Nov 17, 2011 at 8:35:41 pm
Thanks Rafael, got it working!!! Legend.
Andrew Rendell
on Nov 17, 2011 at 5:33:37 pm
I've been using Sony XDCAM Transfer; select Import - XDCAM (the transfer window opens) - click Add and choose the folder with the media in it - select the clips and click Import (it makes copies of the media files that are wrapped as ".mov" and brings them into your project).
Ben Carter
on Nov 17, 2011 at 8:34:40 pm
Thanks a lot mate!!! I downloaded it by googling XDcam transfer, clicked the top link. Simple as!
Thanks heaps...
