Combining PAL HD and NTSC SD
Ian Hines
on Nov 16, 2011 at 3:13:45 pm
I have some PAL HD footage which I want to combine with NTSC SD footage and eventually create an NTSC SD DVD.
What is the best way to combine the formats please? Should I convert the PAL footage and then have all assets in FCP in one format? Could I identify the clips I plan to use and only convert those?
How should I convert the PAL footage?
Something else?
Thanks, Ian
Jerry Hofmann
Re: Combining PAL HD and NTSC SD
on Nov 16, 2011 at 5:33:15 pm
I like Graeme Nattress' filter for this. I'd transcode the footage you want to NTSC before you edit.
http://www.nattress.com/Products/standardsconversion/standardsconversion.ht...
Compressor will also do the transfer, but it's not quite as nice and not as fast.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
eric pautsch
on Nov 16, 2011 at 5:34:27 pm
Is the NTSC 23.98? Down and standards convert in Compressor
