3 cameras - 1 setting in FCP
Dion Johnson
on Nov 16, 2011 at 11:59:59 am
I'm after a little advice. I'm filming a concert performance (band has 3 performers) with 3 cameras...
Cam 1 (main) - Nikon D7000
Cam 2 (cutaways) - Panasonic Z100
Cam 3 (wide shots) - Panasonic Z100
My Nikon D7000 is clearly the better camera (1080p), but I'm restricted with the two cheaper Panasonic cameras only being able to film in 720p at 30fps (29.97fps). Should I bite the bullet and set my Nikon to to 720p and switch from Pal to NTSC enabling me to match the other two at 720p (29.97fps) or should I film in 1080p at 24fps on the D7000 and do some compression/pre-edit work on the other two? There is no budget, and the film will only be shown on the internet, so I'm beginning to think the 720p 30fps option on all three may be best? Don't want to waste a lot of time "adjusting" clips and settings!!!
Keen to know the thoughts of others who may have had similar dilemnas? : - )
Jerry Hofmann
Re: 3 cameras - 1 setting in FCP
on Nov 16, 2011 at 5:29:16 pm
I'd shoot it all the same.
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog:
Current DVD:
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
© 2018 All Rights Reserved
