NTSC frame rates question
Chris Stevens
on Nov 14, 2011 at 4:46:36 pm
I'm not familiar with working with the different frame rates in NTSC. I have clips shot in 23.98fps & 29.97fps. What sequence frame rate should I use to ingest both please?
Cams: Z1, EX3, HDX900.
Post :FCS6, Media 100HD V12, AE7, 12TB Sata Raid & monitoring to die for!
Shane Ross
Re: NTSC frame rates question
on Nov 14, 2011 at 5:43:42 pm
You need to ingest both in the frame rate in which they were shot. You cannot do otherwise, even with a capture card. But then, if you want to mix the formats and have it look good, you need to convert all the footage of one frame rate to the other frame rate. Compressor will do this.
So now you need to settle on which frame rate you want your master to be in.
Shane
