Sync drift on 25fps!???
Ingrid de Beer
on Nov 13, 2011 at 9:43:43 am
Hi there!
I just received the final sound mix (.wav) and dropped it into fcp 7. There seems to be a sync drift. All the settings are matched between fcp and nuendo (25fps, 48 khz, 24-bit, non drop, no pulldown).
Any advice?
Jeremy Garchow
Re: Sync drift on 25fps!???
on Nov 13, 2011 at 5:45:13 pm
Delete the audio out of your project.
Select a 25fps easy setup (control-q)
Quit fcp, reopen fcp.
Reimport audio.
It should now be in sync.
Jeremy
Bella Gavelin
on Nov 16, 2011 at 2:54:03 pm
I just had the same problem all day long.
I found the solution in this tutorial:
http://library.creativecow.net/lyon_matt/fixing-fcp-assets/1
Correcting the timebase in the xml file.
bella
