i want to transfer rushes from FCP to Avid, whats the proper way to do it.
Adnan Malik
on Nov 11, 2011 at 1:14:37 am
I have file that i captured from DVCAM into Final Cut Express, i have also created subclips in FCE. My question is how can i transfer these files with .mov codecs which are DV/ DVCPRO into Avid.
i want to preserve the highest resolution i can with this process.
these files mentioned above are just rushes, i haven't started to edit yet. the only thing i did so far is create subclips.
I am not trying to export the timeline sequence, only the raw capture.
please any help thanks!!
MAC has Final Cut pro, and PC has AVID.
Shane Ross
Re: i want to transfer rushes from FCP to Avid, whats the proper way to do it.
on Nov 11, 2011 at 1:39:54 am
What version of Avid? Give them the raw captures and they should be able to simply AMA them in, or Import them in. DV is a straightforward codec.
Shane
