FCP TEMPLATE 7 TEMPLATES look grainy
stephen sarsfield
on Nov 9, 2011 at 8:22:30 am
I am trying to use the FCP template called glass, when i add the photos they look grainy. when i add the template to my sequence, it is small so i have to blow it up. looks bad. any advise? thanks!
Jerry Hofmann
Re: FCP TEMPLATE 7 TEMPLATES look grainy
on Nov 9, 2011 at 1:53:11 pm
That template is standard definition. If you use it in an SD sequence, it should look great. Otherwise if you put it in an HD sequence, you really need to resize it all in Motion. Element by element...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
