FCP Log and Transfer not converting entire files
Tom Downey
on Nov 8, 2011 at 2:26:18 pm
Shot on Canon 7d's. I'm having a weird problem with FCP. When I use Log and Transfer to convert files it often truncates these files. I checked to make sure I didn't accidentally put a marker for in and out into the original in the L&T window but I did not.
So, for example, a 9 minute video file gets transferred but is missing the last 2:30 of video.
Any ideas on what might be causing this? I have plenty of space on the capture drive, so it can't be that.
I am going to Apple ProRes 422.
Thanks in advance for any help you can offer.
Chris Borjis
Re: FCP Log and Transfer not converting entire files
on Nov 8, 2011 at 5:11:52 pm
I have read other troubles about using log & transfer and the canon plugin so I always use mpeg stream clip.
Works perfectly for me every time.
Rich Rubasch
on Nov 8, 2011 at 8:51:40 pm
While logging and transferring you cannot do any other activity on the computer...then it will work fine.
Rich Rubasch
Tilt Media Inc.
Video Production, Post, Studio Sound Stage
Founder/President/Editor/Designer/Animator
http://www.tiltmedia.com
Phil Balsdon
on Nov 8, 2011 at 10:10:26 pm
I'll second Rich's reply. Once Log and Transfer has started do not use the computer for any other purpose and it will work fine.
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
http://philming.com.au
http://www.steadi-onfilms.com.au/
