60D footage for an event was shot at 1920x1080 24p and some at 1920x1080 30p.
Frank Giardina
on Nov 6, 2011 at 6:09:09 pm
Hi...
I'm not exactly sure how and when it happened, but part of one of our camera operators 60D footage for an event was shot at 1920x1080 24p and some at 1920x1080 30p.
1) The camera operator did not go in the menu to make that change, that's a mystery. Any thoughts on how that might happen?
2) We don't know when the change occurred. Is there a way to check the raw footage to determine is it is 24p or 30p?
3) I've checked a little and there are ways to change 30p to 24p by bringing the 30p footage into a 30p time-line then, converting that sequence to 24p in film tools or after effects. Any best option suggestions would be great :)
Thanks All!
Frank Giardina
17 Video Production
Shane Ross
Re: 60D footage for an event was shot at 1920x1080 24p and some at 1920x1080 30p.
on Nov 6, 2011 at 6:38:45 pm
[Frank Giardina] "1) The camera operator did not go in the menu to make that change, that's a mystery. Any thoughts on how that might happen?"
The camera operator changed the battery maybe? That might make it default to another setting. Other than that...the only way is to manually set it.
[Frank Giardina] "2) We don't know when the change occurred. Is there a way to check the raw footage to determine is it is 24p or 30p?"
Open each clip up in Quicktime, and GET INFO...that will show you.
[Frank Giardina] "3) I've checked a little and there are ways to change 30p to 24p by bringing the 30p footage into a 30p time-line then, converting that sequence to 24p in film tools or after effects. "
No. YOu need to convert the footage BEFORE you bring it into FCP. FCP removes the pulldown wrong. Use Compressor to convert the frame rate.
Shane
Frank Giardina
on Nov 6, 2011 at 6:47:19 pm
Thanks Shane!!!
So, bring each individual 30p clip into compressor and change the frame rate?
Best Regards!!
Frank Giardina
17 Video Production
Shane Ross
on Nov 6, 2011 at 9:03:21 pm
Yup...and you will need to adjust the frame controls to BEST on all the settings.
Shane
Frank Giardina
on Nov 7, 2011 at 5:11:12 pm
Shane... after that, do I have to transcode?
Best Regards!!!
Frank Giardina
17 Video Production
Shane Ross
on Nov 7, 2011 at 5:12:11 pm
That IS how you transcode. You use Clipwrap2 to Transcode the footage to ProRes, or ProRes LT.
Shane
Frank Giardina
on Nov 7, 2011 at 5:20:45 pm
I usually transcode using MPEG Streamclip to get my ProRes files, but with changing 30p to 24P I'm a little confused on the steps to take I guess. I was thinking I would take the 30P raw into Compressor, change it to 24P, then I didn't know if I should edit the new file I get or if there's another step prior to bringing the files into FCP7.
Best Monday Lunch Time Regards!
Frank Giardina
17 Video Production
Shane Ross
on Nov 7, 2011 at 5:22:07 pm
WHOOPS, whoa. Sorry, I was thinking this was another post.
yes, you use Compressor to change the frame rate AND transcode to ProRes at the same time.
Pardon me.
Shane
Frank Giardina
on Nov 8, 2011 at 12:34:45 am
Hi... that sounds good Shane. If you're still there; when in compressor and we select "BEST" for the Rate Conversion, there is also a Set Duration to section. I'm thinking it should be set to match the duration of the raw footage, but one of the options is so source plays at 23.98. What are your thoughts?
Best Regards!
Frank Giardina
17 Video Production
Shane Ross
on Nov 8, 2011 at 12:45:24 am
That setting defaults to 100% of source. Leave it alone.
Shane
Frank Giardina
on Nov 8, 2011 at 2:27:25 pm
OK... I'll try that :
Thanks Shane!!
Frank Giardina
17 Video Production
