editing SD and HD in one project
King Law
on Nov 6, 2011 at 7:19:42 am
i have some SD footage from a client so they also wanted to add some interviews which i shot for them in HD question is, is it possible to edit together SD video clips and HD clips and put to DVD?
Chris Tompkins
Re: editing SD and HD in one project
on Nov 6, 2011 at 11:33:23 am
Yes.
If you are going to SD DVD and no Future need for a Bluray/HD file then
Edit in a SD sequence.
Drop the SD file into a new sequence and let FCP match it.
Then drop in the HD clips and resize/position as needed.
Having the same frame rates will be wise as well.
Chris Tompkins
Video Atlanta LLC
