editing 59.94 vs 29.97
Freddy Allen
on Nov 4, 2011 at 8:22:18 pm
Hello everyone,
My delivery format for a TV network is asking for XDCAM HD422 (50 mb/s) or XDCAM HD (35 mb/s). HD 1080i/59.94 in 16:9 aspect ratio.
Using multiple cameras of different formats I converted all footage to 1080i/29.97 Apple ProRes 422 and Apple XDCam EX 1080p30 which plays at 29.97.
I used easy setup in FCP for XDCam EX 1080i60 (35 VBR) which sets up the sequence for 29.97. Can anyone tell me if this is correct and will I have trouble exporting 1080i/59.94 for the network in the end?
Shane Ross
Re: editing 59.94 vs 29.97
on Nov 4, 2011 at 8:35:17 pm
59.94 at 1080 is 29.97. It's confusing, I know. But 1080i 59.94 means 1080i at 29.97fps. The 59.94 after the "i" indicates FIELDS per second...because it is an interlaced format.
Shane
Freddy Allen
on Nov 4, 2011 at 8:41:05 pm
Thanks Shane. Can I edit in a 29.97 sequence and then export into 59.94 to meet their standards? All footage imported as no field dominance so should I change them to upper or lower or leave them at none?
Shane Ross
on Nov 4, 2011 at 8:57:31 pm
I'm telling you that 29.97 and 59.94 are the same thing at 1080i. It is the same thing...exactly! Just a different way of saying it.
Shane
